16 years agoCyclone III EP3C25 High Temperature Booting Problem
Dear Friends, I am facing a high temperature booting problem with EP3C25F324. I found that the FPGA can not boot up at temperature over 40 Centigrade while doing the temperature cycling tests....
16 years agoActually I used the AS and JTAG combining configuration scheme. I have checked that all the MSEL signals are all directly connected to GND and 2.5 V respectively. But for nCE, I used a 10K ohm as the pull down resistor. This is also the suggestion from the handbook of cyclone III- Chapter 9-figure 9-29:Combining JTAG and AS Configuration Schemes. I exactly followed this scheme.
By the way, during the test, I found that the only thing which can affect the booting process is the high temperature; in room temperature, everything goes well without any problem.
