11 years agoCyclone iii developpment board: DVI problem
Hello all, I create a Sopc system to test my dvi output but it does'nt work. I use a test pattern and a clocked video output, it's a simple system. I use a clock of 108Mhz for a resolution of 1...
11 years ago --- Quote Start --- Where did you get your timing specs for the DVI output? The pixel clock for 1920x1080 @ 60 fps (1080p) is 148.5MHz, not 108MHz. You also have to make sure the horizontal and vertical sync timing and polarity is correct. What is between the FPGA and the DVI output? terasIC DVI-HSMC card? Are you asserting DE to the card correctly? --- Quote End --- Yes thank you, it's 148.5 Mhz. for tha used card it's DVI-HSMC. I just want to make a transmission of an image and display it using DVI. I am using SOPC to create my system: - Clock -Clocked video input -DDR2 -clocked video output But it still doesn't work. Cordially.
