14 years agoCyclone III development Kit
Hello everyone, Our company has provided a Cyclone III development kit and I have to record some digital data on a host PC. As I am new in Altera platforms I have a lot of problems on this matter. F...
14 years ago --- Quote Start --- Unfortunately I don't have a JTAG programmer --- Quote End --- Are you sure? Most kits have them built into the kit, and you just need to add a USB cable. Which kit are you using? --- Quote Start --- So could you please offer an easy solution to implement VHDL codes on the FPGA side and I would be pleased if you could give me a C++ project to capture data through USB and save it in new file. --- Quote End --- The example design contains information on which IP blocks you need to include in your design, and contains a JTAG server and C-coded client. You could replace the client with a C++ version easily enough. Unfortunately you will have to gain some experience with the Altera tools and associated IP. What is the digital data that you have to record? That must involve using the Altera tools and some HDL development. Who is providing the HDL code for that part of the project? Perhaps they can help you integrate the JTAG IP. Cheers, Dave
