14 years agoCyclone III Dev board fitter failure when using SRAM
I am using a Cyclone III EP3C120 Dev board and am having trouble with the fitter when I try to run the I/O Assignment Analysis while using the board's SRAM - it says that there are too many outputs on the VREG group (please see the attached figures). I have made sure that the data bus that is failing is part of an 'Output Enable Group' and I am at a loss for why the fitter is failing, the design appears to be below the 20 allowable outputs for the VREF group. The SRAM has a 32 bit data width and is on a shared bus with the board's flash module. I am using the 'Tri-State Conduit Pin Sharer' to share the data and address buses between the flash and SRAM (QSys figure attached). Any help or suggestions would be greatly appreciated!Thanks!No RepliesBe the first to reply
