12 years agoCyclone III counter problem
Hi all, I seem to have a problem with a counter implementation in Cyclone III. The code is attached below. Bascially, it should generate '1' for 1 clk cycle on parallel_load2 whenever the CNT i...
12 years ago --- Quote Start --- As shown here, the counter value was updated from 241 to 242 on the falling edge of ClientRxRClk. I was thinking maybe there's glitch from my external clock ClientRxRClk, but signalTap II doesn't show this. --- Quote End --- SignalTap acquisition clock frequency is too low to reliably show glitches. Ringing clock edge sounds quite plausible. Usually source side impedance matching will remove ringing.
