15 years agoCyclone III configuration using M25P16 flash
Hi all, I've recently switched config devices from an ST M25P40 to an ST M25P16 flash for a design using a Cyclone III EP3C10 (in active serial mode). I've wired up the flash as indicated in t...
15 years agoyou might try turning on the Disable AS mode CONF_DONE error check in the Advanced Options of the Convert Programming Files menu
