15 years agoCyclone III configuration using M25P16 flash
Hi all, I've recently switched config devices from an ST M25P40 to an ST M25P16 flash for a design using a Cyclone III EP3C10 (in active serial mode). I've wired up the flash as indicated in t...
15 years ago --- Quote Start --- Sounds as though the M25P16 has a slightly higher drive strength than the M25P40 --- Quote End --- DCLK is driven by the FPGA, not the serial flash. The initial poster didn't tell about the FPGA to flash distance. If it's large, clock signal integrity problems without a series termination aren't surprising.
