15 years agoCyclone III configuration using M25P16 flash
Hi all, I've recently switched config devices from an ST M25P40 to an ST M25P16 flash for a design using a Cyclone III EP3C10 (in active serial mode). I've wired up the flash as indicated in t...
15 years agoOK, fixed it - I needed to add a series termination resistor to the DCLK line. Ideally this would be close to the FPGA, but since that is inaccessible on my board I put it at the receiving end - the config flash clock pin - and the problem is fixed. I guess this larger flash has a lower pin capacitance than the devices I was using previously.
