14 years agoCyclone III configuration corrupts image
All, We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like...
14 years agoI was just reading through this thread and wonder if you had the JTAG pull-ups and power on header pin 4 connected to 3.3V or 2.5V in your initial layout.
If so that's a possible issue. On Cyclone III the JTAG interface is based on VCCA which is 2.5V so that should the voltage connect to pin 4 of the header and used for the pull-ups on TDI and TMS. I know we had issue with JTAG configuration when we had these connected to 3.3V on one of our boards. See Figure 9-24 in the handbook. Note if the VCCIO is < 2.5V then these are connected to the VCCIO rail for the bank. as in figure 9-25
