14 years agoCyclone III configuration corrupts image
All, We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like...
14 years ago --- Quote Start --- We come to the conclusion that it's a manufacturing issue, perhaps aided by a "less than optimal" layout. Since we now have a work-around, we're going to cross our fingers and hope the next design works better. --- Quote End --- Is the 'next design' a completely difference design, or the same design with a cleaner PCB layout? Regardless, I would recommend you plan on creating a small run of prototype/pre-roduction boards, and confirm the issue has been resolved. I typically find that 5 boards is a good minimum number of boards, as it allows you to discard one or two boards with assembly related issues, and focus on the real problems. Cheers, Dave
