14 years agoCyclone III configuration corrupts image
All, We have 30 boards with a single EP3c25 wired for JTAG and AS configuration, as per the handbook. Several pairs of eyes have peered at the schematic and the boards and everything looks like...
14 years ago --- Quote Start --- As I understand it, CRC wouldn't help in this case: If the image is corrupted on download, the CRC would be computed on the corrupted image and tell you nothing. --- Quote End --- The asumption is wrong. The CRC is compared to a precomputed value. You didn't answer the question about verify. It's also unclear, if you are programming the serial flash through indirect JTAG or AS interface. --- Quote Start --- Remember, once the image has been saved into EPCS, we have no problem bringing the board up. It's ONLY through the JTAG that there's a problem. --- Quote End --- So the image does not verify correctly? In this case it's most likely a problem of JTAG or AS interface signal quality.
