14 years agoCyclone III AS configuration problem (yes another)
First thanks for all you experts who answers posts... If I become and expert I will answer some myself. I am having similar difficulties as others with AS configurations. Here is what I have don...
14 years agoWhat are your power supplies like, are they up to the job?
There is an inrush current on VccInt (on some devices) which can be >> normal operating current. If your supplies aren't up to this it might be causing what you're seeing. Also, how far away is the config device to the FPGA? Controlled impedance tracks? Tracks with associated ground planes not crossing slots? No long parallel tracks that could be coupling crosstalk? I always place the config device and the JTAG header as close to the FPGA as possible (all else considered) on the assumption that reliable configuration's the first step to producing a reliable board! I'm also almost exclusively using JIC config from the JTAG header. This usualy allows shorter tracks all round. Nial.
