14 years agoCyclone III AS configuration problem (yes another)
First thanks for all you experts who answers posts... If I become and expert I will answer some myself. I am having similar difficulties as others with AS configurations. Here is what I have don...
14 years agoYour report is unclear. It's apparently mixing AS device programming and configuration problems. Obviously, the AS configurations device must be programmed and verified correctly before you can expect it to configure the FPGA succesfully.
If the programmer can't access the AS device, there seems to be a hardwarwe problem in your design which must be fixed first. Apart from programming the AS configuration device, you can do it also through JTAG indirect programming. Did you notice?
