19 years agoCyclone III AS configuration bizarreness
I am using a cyclone III (EP3C25F324C8N) with an EPCS16 configuration device. I am programming the configuration device through the FPGA with the serial flash loader. The problem is that the Cyc...
17 years agoIn that case I do not know. Only thing I can suggest is to slow down the clock and make sure that JTAG pins are pulled up/down to inactive level, as the guru said few posts above.
Good luck.
