19 years agoCyclone III AS configuration bizarreness
I am using a cyclone III (EP3C25F324C8N) with an EPCS16 configuration device. I am programming the configuration device through the FPGA with the serial flash loader. The problem is that the Cyc...
17 years agoI have a similar problem and just as described, while probing either nCONFIG lines or nCONFIG_DONE things started to work from then on.
Has anyone discovered or solved what causes this erratic configuration problem?
