19 years agoCyclone II Serial Config
I'm having a rather odd problem and I was wondering whether anyone else has experienced it.
I'm using an M25P40 serial prom with an EP2C20. Standard setup, in fact we reused the schematics from a previous project and repinned the FPGA. The only difference is that it's a Cyclone II instead of a Cyclone part. We've only built 4 boards and they are all flakey. The problem is that the proms are mysteriously unprogramming themselves during normal operation. That is, the Cyclone II won't configure until the prom is reprogrammed. Sometimes the serial prom can't be reprogrammed and must be replaced. Any ideas? Thanks for your help. Leslie41 Replies
Maybe because Altera only officially supports its own low cost serial configuration devices... why don't you use an EPCS device from Altera instead. You haven't provided a lot of details about your configuration scheme so it's hard to make any suggestions to you about things to try. Are you using passive or active? Sounds like active. Then you are clearly using a serial PROM that isn't supported.
Try these documents http://www.altera.com/literature/hb/cfg/cfg_cf51001.pdf http://www.altera.com/literature/hb/cyc2/cyc2_cii51013.pdf
