19 years agoCyclone II Serial Config
I'm having a rather odd problem and I was wondering whether anyone else has experienced it. I'm using an M25P40 serial prom with an EP2C20. Standard setup, in fact we reused the schematics fro...
19 years ago --- Quote Start --- I use quartus 6.1 to convert the file.and the FPGA is EP2C5,The ST ID is 25PE16V6.I Will buy some M25P40 to try it . --- Quote End --- I´m using quartus 7.1. are you shure that you have selectet the right EPCS device for the .jic conversion? use quartus 7.1, maybe there will be the silicon ID reportet, as it was in my case.
