19 years agoCyclone II Serial Config
I'm having a rather odd problem and I was wondering whether anyone else has experienced it. I'm using an M25P40 serial prom with an EP2C20. Standard setup, in fact we reused the schematics fro...
19 years agoThe error says everything you need to know...
Your jic ist apparently not one for an EPCS16. It is for an EPCS4. Two reasons: You selected the false programming file, or you selected the wrong device when converting. When converting your pof File into jic you should select the correct device. This is EPCS16 not EPCS4. ;-) Regards
