19 years agoCyclone II Serial Config
I'm having a rather odd problem and I was wondering whether anyone else has experienced it. I'm using an M25P40 serial prom with an EP2C20. Standard setup, in fact we reused the schematics fro...
19 years agoHi stephenzhou,
it really doesn't matter. The pullups are just, i would say, nice to have. :cool: You can bypass them an connect those pins directly to VCC if you want to. (When you don't have the place or its to expensive). --- Quote Start --- so did you use M25P10? M25P80? M25P16 for EPCS1? --- Quote End --- I always used the M25P40 as replacement for the EPCS4 because there was no need for smaller parts. I'm not really sure, but i would say the M25P10 is comparable to EPCS1. I would advise you to compare the datasheets of the M25Pxx devices with the datsheets of EPCSx devices, then you will see what you need. (I hope so!) Christian
