19 years agoCyclone II Serial Config
I'm having a rather odd problem and I was wondering whether anyone else has experienced it. I'm using an M25P40 serial prom with an EP2C20. Standard setup, in fact we reused the schematics fro...
19 years agoWe use here the M25P40 Devices with the EP2C8 without any problems on some hundreds of boards. So I think there is something wrong with the wiring of the Pins on your boards. Do you have access to the JTAG pins of the Cyclone II? So you can try to program the M25P40 using a *.jic Files via JTAG(Quartus II -> File -> Convert Programming Files)
Christian
