19 years agoCyclone II Serial Config
I'm having a rather odd problem and I was wondering whether anyone else has experienced it. I'm using an M25P40 serial prom with an EP2C20. Standard setup, in fact we reused the schematics fro...
19 years agoHi,
I also use an ST M25P40 SPI flash with an EP2C8 in AS scheme, this without any problem. Did you check M25P40 SPI lines during normal operation (I mean after configuration) ? Maybe the M25P40 is chip selected in an unexpected way. Also ensure that M25P40 CS pin is pullup'ed. See M25P40 ST specs about power-on/power-down behaviour. Hope this will help :) .
