19 years agoCyclone II Serial Config
I'm having a rather odd problem and I was wondering whether anyone else has experienced it. I'm using an M25P40 serial prom with an EP2C20. Standard setup, in fact we reused the schematics fro...
19 years agoThanks for the quick reply.
What, you don't read minds? ;) The serial config device is set up for AS programming. Both MSEL tied low on the Cyclone II and a separate JTAG connector. Wiring, pull-up and pull-down resistors are all correct. Switching to the Altera part was my first guess, too. Not sure why we are using the other in the first place. I fired off an email suggesting the EPCS4 at about the same time as I wrote the first post about my problem. I had read the documents you listed - and read them carefully hoping I'd overlooked some tiny detail. Nada. It's odd only because we've used the M25P40 in the exact same circuit on several designs without a problem. I'll post a follow-up after the boards come back from the field and I can actually look at one.
