19 years agoCyclone II PS configuration problem
Hi all, I am trying to configure 3 EP2C20 with 3 EPC2 device. The EPC2 device was configured with JTAG. So when the board power up the EP2C20 should be configured by the EPC2. The connec...
19 years agoHi
I hope the cascadded conecction is perfect!!.. well I found this on Altera Cyclone handbook.. just check this up The enhanced configuration devices’ and EPC2 devices’ OE and nCS pins have internal programmable pull-up resistors. If internal pull-up resistors are used, external pull-up resistors should not be used on these pins. The internal pull-up resistors are used by default in the Quartus II software. To turn off the internal pull-up resistors, check the Disable nCS and OE pull-ups on configuration device option when generating programming files. Cheers
