14 years agoCyclone II PLL - without wizard
Hi, I am trying to use the PLL blocks in a Cyclone II outside the limits of the megafunction wizard. I've pushed the VCO far outside the range by lying to it, and would like to access the p...
14 years ago --- Quote Start --- I am trying to use the PLL blocks in a Cyclone II outside the limits of the megafunction wizard. I've pushed the VCO far outside the range by lying to it, and would like to access the phase comparator directly so that I can run the input much slower. --- Quote End --- Have you looked at the ALTPLL_RECONFIG Megacore? http://www.altera.com/literature/ug/ug_altpll_reconfig.pdf Cheers, Dave
