17 years agoCyclone II Max Clock Rate
Hi all, I am new to FPGA design and I am trying to get the most from my chip (EP2C20F484C7N). I have tried searching but everywhere seems to say different with no real reason to why that is the...
17 years agoI would start of by ignoring the clock rate and putting down some logic. There's a decent chance the design is going to be topping out around that speed anyway. It is possible to do rise->fall->rise transfers to get more work done, but not done very often. If there isn't a feedback path within that logic, just get rid of the middle falling-edge register and the same amount of logic will be done between registers. (And there's no way you'll be getting 520Mbps rates in that part, so you'll most likely be running much slower probably 200MHz or less, with occasional burst that are faster.)
But really start designing your HDL and you'll probably find other issue. The clock tree FMAX seldom comes into play except for the occasional small slivers of logic.
