19 years agoCyclone II is not working correct???
Hello, I have written a small process, which should read a dmx-signal (seriell signal with special timings). THe whole thing is working realy good, but sometimes it makes things, which i hav...
19 years agoIn addition QuartusII has some settings to Auto Set up State Machine and which FSM has to generate if you set AUTO to ON. (ex. One Shot).
When QII recognize a FSM, it converts and increase the efficiency of the states coding by itself. If you don't want this, set the variable to OFF. Have a look in the Assignments in QII. bye
