19 years agoCyclone II configuration problem
Dear all, I am using an EP2C50F672 Cyclone II FPGA and I am facing problems booting it from the EP2C16. All connections with MSEL and related config pins of FPGA are as advised in datasheet. ...
19 years agoHi,
Apparently something is wrong with AS configuration pins on your board. Are you having the same results on other boards as well? If yes, then try taking look at the AS Mode configuration pins status when you initiate the configuration and when the configuration completes. Are all the signals showing correct state or one/few pins are showing weird state? Try to monitor the status of nCONFIG, nSTATUS, nCE, nCEO and CONF_DONE pins during and after configuration in AS Mode. I don't know how much it will help, but you could also try followings: FPGA Configuration Troubleshooter: http://www.altera.com/cgi-bin/ts.pl?fn=configuration Debugging Configuration Problems: http://www.altera.com/literature/hb/cfg/cfg_ch11_vol2.pdf Hope this helps. BD
