19 years agoCyclone II configuration problem
Dear all, I am using an EP2C50F672 Cyclone II FPGA and I am facing problems booting it from the EP2C16. All connections with MSEL and related config pins of FPGA are as advised in datasheet. ...
19 years agoHi stefanos,
Well what I understand from your post you are able to run your FPGA as per your design via .sof(configuring FPGA alone) but unable to do so if you write .pof to EPCS. Well just check up Assignments->settings->device->configuation settings and uncheck the Compressed bitstream option. Recompile and give it a try. If your hardware is fine it should work.
