19 years agoCyclone II configuration problem
Dear all, I am using an EP2C50F672 Cyclone II FPGA and I am facing problems booting it from the EP2C16. All connections with MSEL and related config pins of FPGA are as advised in datasheet. ...
19 years agoDear all,
we are using the EP2C50672C6 FPGA and the EPCS16 as the boot device. We connect MSEL0 ----- GND MSEL1 ----- GND setting for AS NCE ----- GND N_STATUS --- weak pulled up N_CONFIG --- weak pulled up CONF_DONE --- weak pulled up All connections based on Altera datasheets. However, device won't start reading from EPCS at power up. Contacted a number of people for support and still no luck.
