19 years agoCyclone II configuration problem
Dear all, I am using an EP2C50F672 Cyclone II FPGA and I am facing problems booting it from the EP2C16. All connections with MSEL and related config pins of FPGA are as advised in datasheet. ...
19 years agoI am a little confused.
Are you using the EP2C16 as a boot device? Do you mean the EPCS16? Please clarify. Then also provide all you interconnections and MSEL connections in a table. Thanks.
