14 years agoCyclone II Configuration Basics
I am designing with the EPC3C5F256C8N. I will initially configure with the EPCS4 and then,later, configure from a serial flash via a microcontroller. I have been digging through the Altera...
14 years ago --- Quote Start --- What most people do is use option "a)". Then we just apply what's described in the "Converting .sof to .jic Files in the Quartus II Software" and "Programming Serial Configuration Devices Using the Quartus II Programmer and .jic Files" parts of the app note. It just requires a few more clicks to generate the programming file. --- Quote End --- +1 here. It takes a minute or two to produce the JIC the first time then you can safe the COF for the convert programming tool. I then add a script to the design flow so this happens automatically when I build the device. No extra hassle and just wiring to the JTAG header usually allows much more compact (/noise immune) routing. Nial.
