Altium_user
5 years agoCyclone II / NIOS II alt_flash_open_dev("/dev/epcs_controller") issues (EPCQ)
Good afternoon,
Quartus 13.0.1 Build 232, (EP2C20), Windows 10, 64BIT (working on legacy project..)
I'm struggling with a Flash Memory upgrade. I've been using EPCQ16 for a while now, and without...
SyafieqS
5 years agoMatthew,
Is this issue occur in latest version of Quartus for you supported device?
Can you use latest version I believe this should be fixed.
Altium_user
5 years agoGood Morning SyafieqS_Intel,
The versions of Quartus/NIOS that I can use is pretty limited because of applicability to device - I have to work with Cyclone II compatible Quartus/NIOS, which ceases with Quartus/NIOS > v13.1.
I would have to try other versions to see what happens, but I'm a little concerend that this wouldn't work because support for the FPGA wouldn't be there.
Anything above the support level would mean that spurious behaviour may occur.
I've recently downloaded v21.1, so I ought to try that.
M
