19 years agoCyclone II - losing configuration after power off
Hi. I programe FPGA through JTAG (MSEL0, MSEL, nCE, DCLK0->GND; nCONFIG->VCC; nSTATUS, CONFIG_DONE->VCC through resistor). I'm using QuartusII (Device & Pin Options: Configuration scheme: PS - I c...
19 years agoHi klombi
1. First of all make sure that you use a .pof file and upload it to eprom (EPC, EPCS...etc) 2. If you use a .sof it's normally that you lose a data after shut down, cause FPGA is a SRAM based device. Also try to check sinthesizer . As I remember there is check that enables conf.device ...look for it somewhere there..
