19 years agoCyclone II ---> DVI out
Hi, Has anyone experimented using a serdes to feed directrly video from an Altera Cyclone or Cyclone II device to a DVI monitor? Without an external power hungry serializer chip? I know that th...
19 years agoHi,
The DVI signals are differential current fed signals. The DVI spec can be found at: http://www.ddwg.org/lib/dvi_10.pdf Starting at page 33 you'll find the electrical specification, too long to describe here. The standard states a current fed differential signalling, but using just a short cable and proper resistive loads/impedance matching it might be possible to achieve this even with a voltage output at Cyclone I/II ?? Or are there any other vendors that have FPGA's that can do DVI directly?? Regards, Christian
