18 years ago
Cyclone development board and its P30 Flash
Dear Sir/Madam
I am trying to program the Intel's Flash P30 using my FPGA. Could you please help me out, as i am having not luck. What i would like to do is store 16-bit binary word at certain locations. I am using VHDL, and my FPGA is using 1 Mhz, so that timming is not really a issue. So in the first clock cycle i assert the following signal as show below.
we<='0';
ce <= '0';
rs <= '1';
oe<='1';
adv <= '0';
and then in the next clock cycle
we<='1';
ce<='1';
A <=(others=>'1');--- address
DQ<="0000000000001010";--bit stream
This is what i understood from the datasheet, this should add my 16-bit stream in the location.
And to read what i have input i would assert the following signal
ce <= '0';
oe <= '0';
we<='1';
adv<='0';
Please do get back, as i am slighly stranded in my university project.
My vhdl code is below, and inorder to check that some data is stored i try to read the data and assign the last 4 bits to the LED on the board, but as the data is bi directional it seems to be show the correct LED lightling up, but if i was to removing the part of the code that writes data and only run the part which reads from that location now led's light up.
Please do get back, as i am slighly stranded in my university project and my Uni dont no much about such devices.
IBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_arith.all;
ENTITY PT IS
PORT(
CLK_H : IN std_logic;
RS_H : IN std_logic;
A : OUT std_logic_vector (24 DOWNTO 0);
B : OUT std_logic_vector (3 DOWNTO 0);
adv : OUT std_logic;
ce : OUT std_logic;
clk : OUT std_logic;
oe : OUT std_logic;
rs : OUT std_logic;
we : OUT std_logic;
wt : OUT std_logic;
DQ : INOUT std_logic_vector (15 DOWNTO 0)
-- Declarations
END PT ;
-- hds interface_end
LIBRARY ieee;
ARCHITECTURE fsm OF PT IS
-- Architecture Declarations
TYPE STATE_TYPE IS (
s0,
s2,
s3,
s4,
s6,
s1
-- State vector declaration
ATTRIBUTE state_vector : string;
ATTRIBUTE state_vector OF fsm : ARCHITECTURE IS "current_state" ;
-- Declare current and next state signals
SIGNAL current_state : STATE_TYPE ;
SIGNAL next_state : STATE_TYPE ;
BEGIN
clocked : PROCESS(
CLK_H,
RS_H
BEGIN
IF (RS_H = '1') THEN
current_state <= s0;
-- Reset Values
ELSIF (CLK_H'EVENT AND CLK_H = '1') THEN
current_state <= next_state;
-- Default Assignment To Internals
END IF;
END PROCESS clocked;
nextstate : PROCESS (
current_state
BEGIN
CASE current_state IS
WHEN s0 =>
next_state <= s2;
WHEN s2 =>
next_state <= s3;
WHEN s3 =>
next_state <= s1;
WHEN s4 =>
next_state <= s6;
WHEN s6 =>
next_state <= s6;
WHEN s1 =>
next_state <= s4;
WHEN OTHERS =>
next_state <= s0;
END CASE;
END PROCESS nextstate;
output : PROCESS (
DQ,
current_state
BEGIN
-- State Actions
WHEN s0 =>
-- A <=(others=>'1');
--DQ<="0000000000000000";
WHEN s2 =>
we<='0';
ce <= '0';
rs <= '1';
oe<='1';
adv <= '0';
WHEN s3 =>
we<='1';
ce<='1';
A <=(others=>'1');
WHEN s4 =>
ce <= '0';
oe <= '0';
we<='1';
adv<='0';
WHEN s6 =>
B <= DQ(3 downto 0);
WHEN OTHERS =>
NULL;
END CASE;
END PROCESS output;
-- Concurrent Statements
clk<=clk_H;
END fsm;
Thanking you in advance
Yours Sincerely
Dharmesh Joshi
    The sequence is always
    Reset -> Erase -> Program -> Busy -> Verify
    The program sequence is
    Program0 ~ Program7 in my last reply
    Dear Sir
    Thank you for your reply.
    I have made changed to my VHDL code but found that it does not improve what i am trying to do. If possible could you further guide, please do note, that i havent erased the flash as my code for my other design is also on that design and iam using the last memory address to save my 16-bit word. I am also using the same clock that drives the state machine for the flash. Please do not that the all signals on the flash are asserted low. My VHDL code is below:LIBRARY ieee;
    ENTITY PT IS
    PORT(
    ce : OUT std_logic;
    oe : OUT std_logic;
    rs : OUT std_logic;
    we : OUT std_logic;
    wt : OUT std_logic;
    END PT ;
    LIBRARY ieee;
    s0,
    s3,
    s4,
    s6,
    s1,
    s5,
    s7,
    s2,
    s8
    BEGIN
    clocked : PROCESS(
    CLK_H,
    RS_H
    BEGIN
    IF (RS_H = '0') THEN
    -- Reset Values
    END IF;
    current_state
    BEGIN
    WHEN s0 =>
    next_state <= s8;
    WHEN s3 =>
    next_state <= s1;
    WHEN s4 =>
    next_state <= s6;
    WHEN s6 =>
    next_state <= s6;
    WHEN s1 =>
    next_state <= s7;
    WHEN s5 =>
    next_state <= s3;
    WHEN s7 =>
    next_state <= s2;
    WHEN s2 =>
    next_state <= s4;
    WHEN s8 =>
    next_state <= s5;
    WHEN OTHERS =>
    next_state <= s0;
    END CASE;
    output : PROCESS (
    DQ,
    current_state
    BEGIN
    -- State Actions
    WHEN s0 =>
    rs <= '0';
    CE<='0';
    WE<='0';
    oe<='1';
    adv <= '1';
    B<=(others=>'1');
    WHEN s3 =>
    A <=(others=>'1');
    we<='0';
    adv <= '0';
    WHEN s4 =>
    oe <= '0';
    A <=(others=>'1');
    adv <= '0';
    WHEN s6 =>
    WHEN s1 =>
    we<='1';
    adv<='1';
    WHEN s5 =>
    we<='1';
    WHEN s7 =>
    we<='0';
    adv <= '0';
    A <=(others=>'1');
    WHEN s2 =>
    we<='1';
    adv<='1';
    WHEN s8 =>
    rs<='1';
    WHEN OTHERS =>
    NULL;
    END CASE;
    END PROCESS output;
    clk<=clk_H;
    END fsm;
    Please do advice me
    Thank You
    Dharmesh Joshi
    1/ As I remember, you don't need to toggle CE & WE at the same time.
    2/ We did NOR flash Emulator for Spansion, STM, SST, Winbond, MXIC.
    All of them need to do following sequence if you're trying to write correctly:
    Reset -> Erase -> Program -> Check Ready Pin -> Verify(Read)
    Which means I have to following sequence
    (VHDL code just for telling you the seq, not really working)
    When Reset0=> D(7 downto 0)<="11110000"; CE<='0'; WE<='0'; --F0
    When Reset1=> WE<='1';
    When Erase=> -- depends on where and which kind of Erase you want, sequence is like program
    When Program0=> D(7 downto 0)<= "10101010";
    [/INDENT]A(10 downto 0)<="10101010101"; WE<='0'; --555/AA
    When Program1=> WE<='1';
    When Program2=> D(7 downto 0)<= "01010101";
    [/INDENT]A(10 downto 0)<="01010101010"; WE<='0'; --2AA/55
    When Program3=> WE<='1';
    When Program4=> D(7 downto 0)<= "10100000";
    [/INDENT]A(10 downto 0)<="10101010101"; WE<='0'; --555/A0
    When Program5=> WE<='1';
    When Program6=> D<="your data"; A<="your address"; WE<='0';
    When Program7=> WE<='1';
    -- Then, do Ready/Busy pin check
    -- And now you can read it
    I believe Intel's Strata Flash do so.
    Our Related Emulator: http://www.samedisk.com/en/forum/viewforum.php?f=5 (http://www.samedisk.com/en/forum/viewforum.php?f=5)
    Joshi,
    Can you go in and edit your intitial post and remove all the extra spaces?
    THanks,
    Avatar
