9 years agoCyclone 5 maximum size DDR3
For Cyclone 5 FPGAs, what is the maximum size of the DDR3 memory in GB that can be connected to the FPGA hard memory controller and the HPS memory controller? I took a fast look on the datasheet b...
9 years agoMaximum size will be determined by the specific Cyclone V device you chose, the IP and the number of instances of that IP you're allowed/able to fit in the device. I suggest you play around with the IP configuration tool for the device you're interested in.
Cheers, Alex
