9 years agoCyclone 5 custom board PLL issues
I created a board for cyclone 5 soc 5CSEBA5U19. The design behaves in a strange way. (hardware design) The JTAG chain has the HPS then the FPGA in series, like in DE1-SOC eval board. The FP...
9 years agoI also thought that it should lose lock sometimes because of the supply. But believe me that is not the case.
I tried feeding the PLL with 50Mhz and 25Mhz and modified the PLL parameters to accept this but nothing worked. I also revised the PLL parameters many times. I checked the fitter report to see the min and max locking frequency and my input is in range. I enabled the auto reset and disabled it but nothing worked. I I also simulated the PLLs and the simulation was good. I have some more boards that I can assemble and will check if this issue is repeated in the third board. Thanks
