15 years agocyclone 3 starter kit. permanent configuration rom
Is there a way to permanently program a jic file (or other) to the cyclone 3 starter kit, or does it only use sof files download over the usb/blaster interface? aka It would be nice to be able to do ...
15 years agoHello,
You can use active parallel flash configuration. Check out Appendix A in the starter kit user guide. I'm not allowed to post a link to it directly (due to forum restriction), but Google for "cyclone iii starter kit user guide" and you should find it easily enough. It's under altera.com plus the following path.... /literature/ug/ug_ciii_starter_kit.pdf ;) Hope this helps, Chris.
