15 years agocyclone 3 starter kit. permanent configuration rom
Is there a way to permanently program a jic file (or other) to the cyclone 3 starter kit, or does it only use sof files download over the usb/blaster interface? aka It would be nice to be able to do ...
15 years agoI presume you have the EP3C25 starter board, which is hardwired for an active parallel configuration (look at MSEL pins). So you can possibly boot from the parallel flash (Intel 64Mbytes?).
I think you need to program it using the .pof file; anyway you can generate the correct file using the file conversion function available in Quartus. I have a different dev board and I always used serial configuration, so I can't help you more than this. Cris
