11 years agocyclone 3 PLL[1..4]_CLKOUTp
Hello to all! I'm reading the "Pin Connection Guidelines" for cyclone3 and cyclone4E. In cyclone3 doc i read : "These pins can only use the differential I/O standard if it is being fed by a P...
11 years agoYou will be able to use both clkoutp & clkoutn as independent general purpose, single ended I/O.
Can I assume you want to drive clkoutp from the PLL? Yes, you should be able to both drive clkoutp (as a single ended signal) from the PLL and use clkoutn as a general purpose I/O pin. I've just tried this, successfully, albeit with a Cyclone IV part - I don't have Cyclone III installed. It will quite happily allow me to use clkoutn as an input or output signal whilst using clkoutp as a single ended PLL output signal. Put a small project together and let Quartus give you the answer for Cyclone III. Cheers, Alex
