11 years agocyclone 3 PLL[1..4]_CLKOUTp
Hello to all! I'm reading the "Pin Connection Guidelines" for cyclone3 and cyclone4E. In cyclone3 doc i read : "These pins can only use the differential I/O standard if it is being fed by a P...
11 years agoYes, you can use dedicated PLL outputs in single ended mode on a cyclone3. This is not inconsistent with the statement "These pins can only use the differential I/O standard if it is being fed by a PLL output".
