12 years agoCyclone 3 E144 package getting hot and Cannot program the Cyclone using EPSC4 Chip
Thanks in advance, for any help you guys can provide . I'm trying to configure a Cyclone 3 (EP3C5E144) device using AS configuration mode. I'm currently using the EPCS4 chip for the AS mode configu...
12 years ago --- Quote Start --- I will have to put that together. I don't really have a board design yet. It is currently all under prototypes. I connected the circuit together using wire wrapping techniques and soldering to a prototype board. --- Quote End --- Ah, I see. Then the fact that your IC is getting hot may be due to an ESD problem you created while building the board. If this was a nice "clean" PCB and you had the same issue on multiple instances of the PCB, then the issue could be a design error. In the case of a problem with a single instance, its a bit more difficult to assign "blame". Can you switch out the FPGA for another? --- Quote Start --- One thing I've forgotten to answer you from the previous reply is the version and configuration Quartus. I'm currently using Quartus II 32 Bit version 13.1.0 Build 162, the unused pins is set to "As Input Tri-Stated with weak pull-up". --- Quote End --- Ok, then there should not be any driver conflict. --- Quote Start --- Let me know if that is sufficient as a schematic diagram ... --- Quote End --- It sounds like you've implemented everything correctly. Have you looked at your power-on waveforms? Are the regulator ramps monotonic? Do each of the power rails come on in sequence correctly? Does the nSTATUS pin deassert high, and does the AS mode configuration start (DCLK toggles)? Cheers, Dave
