15 years agoCyclone 3 ALTREMOTE_UPDATE+ALTASMI_PARALLEL
Guys, I need you help. I'm trying to implement a factory image that receives a new application image through a UART, writes its to the FLASH (EPCS4) and triggers a reconfig. I'm not using NIOS. ...
15 years agoNo need to mux them.
Just instantiate them, Quartus takes care of connecting the signals to the EPCS4 automatically, you do NOT need to assign the pins in pin planner. You also do not need to specify timing constraints. Again, no need to mux.
