15 years agoCyclone 3 ALTREMOTE_UPDATE+ALTASMI_PARALLEL
Guys, I need you help. I'm trying to implement a factory image that receives a new application image through a UART, writes its to the FLASH (EPCS4) and triggers a reconfig. I'm not using NIOS. ...
15 years agoThanks amilcar,
Let me make my question clearer: Since both ALTREMOTE_UPDATE and ALTASMI_PARALLEL interface to the EPCS4 FLASH how do you mux them? In AN603 the ALTREMOTE_UPDATE has extra input and output port that interface to the ALTASMI_PARALLEL And then you can mux your logic and ALTREMOTE_UPDATE. BUt in Cyclone 3 these ports are not available. Am I missing something?
