ADTL_belveera
4 years agoCyclone 10GX device DDR3L & Parallel Flash devices pinouts
We are using the Cyclone 10GX FPGA device 10CX105YF672I5G along with Micron make DDR3L device MT41K128M16JT-125 and Spansion make 16-bit NIOS compatible CFI Flash device S29GL256P10TFI010 in our de...
AdzimZM_Altera
4 years agoHello,
Thank you for using Intel Community.
First of all, can you separate this thread into two thread?
You can use this thread for the EMIF side.
The new thread should be for flash device.
The reason for that is for better support from Intel expert in each area.
In order to find appropriate pinouts, you may need to refer to Pinout file from this link:https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/dp/cyclone-10/10cx105.xls
When you open the 10cx105.xls, you should refer to Pin List F672 which is a reference for the device that you used.
Please let me know if you have further question in this topic.
Adzim
