GLees
Contributor
2 years agoCyclone 10GX DDR3 EMIF Clock Input
I've instantiated a DDR3 EMIF in banks 2K & 2J (1.5V I/O) of a Cyclone 10GX220 device. I let Quartus choose the pin locations. Quartus assigns a differential clock with an LVDS interface for the pll_ref_clk input. I have two questions;
1. Can I force Quartus to accept a single ended, 1.5V clock instead?
2. If not, will the 1.5V I/O bank actually accept an LVDS clock? Typically a 1.8V I/O bank is used for LVDS signals.
1 Reply
- AdzimZM_Altera
"1. Can I force Quartus to accept a single ended, 1.5V clock instead?"
- Yes the PLL reference clock can be single-ended clock or differential clock.
"2. If not, will the 1.5V I/O bank actually accept an LVDS clock? Typically a 1.8V I/O bank is used for LVDS signals."
- Yes there are dedicated clock pins in the I/O bank for the PLL reference clock.
- Setting this clock pin to use LVDS I/O standard should be fine.
Adzim
