Cyclone 10 use bank 2L for an LVDS clock input
Hello Bohris,
May I know what errors you the fitter generate after you use LVDS clock as PLL reference.
- Bohris5 years ago
with single ended PLL refclk (PLL reference clock I/O standard: SSTL-135) at PIN_F23 the compilation is successful.
Using LVDS (with or without On-ChipTermination) the following error occurs:Error (14566): The Fitter cannot place 1 periphery component(s) due to conflicts with existing constraints (1 pin(s)).
Error (175020): The Fitter cannot place logic pin in region (38, 87) to (38, 88), to which it is constrained, because there are no valid locations in the region for logic of this type.
Info (14596): Information about the failing component(s):
Info (175028): The pin name(s): EMIF_REFCLK
Error (16234): No legal location could be found out of 1 considered location(s). Reasons why each location could not be used are summarized below:
Error (179009): Could not find enough available I/O pin locations that supports the LVDS standard (1 location affected)
Info (175029): pin containing PIN_F23
Info (175015): The I/O pad EMIF_REFCLK is constrained to the location PIN_F23 due to: User Location Constraints (PIN_F23)
Info (14709): The constrained I/O pad is contained within this pin
Error (15307): Cannot apply project assignments to the design due to illegal or conflicting assignments. Refer to the other messages for corrective action.
