8 years agoCyclone 10 LP
how to interface SPI in cyclone 10 LP FPGA and FRDM-25KLZ through PATFORM DESIGNER.
Thank you, Preeti3 Replies
where to give the inputs,as I m supposed to generate a clock of 1 MHZ.we is the testbench and how to generate it.
thank you so much
Using QSYS/Platform designer design a system, With SIP IP and export the interface and connect physically to the FRDM-25KLZ board. Set appropriate slave/master configuration in SPI IP. https://www.alteraforum.com/forum/attachment.php?attachmentid=14665 Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
