ChathEsh
2 years agoCyclone 10 LP VccIO
I have a Cyclone 10 LP based design where VccIO of one of the IO banks is being supplied by a 3.3V, but the output pins are configured as 1.8V. This is caused by use of same firmware in different har...
FvM
2 years agoShould be safe. Bank voltage settings are used to configure output drive strength. Outputs can be overloaded if you set higher drive strength than allowed for 3.3 V and connect low impedance load.
