Cyclone 10 LP reverting to factory image unexpectedly
Yes, the re-config trigger conditions register always says what the User Watchdog Timer Timeout caused the re-config.
Given that I can't make this work reliably without extending the duration of the Avalon write pulse to 2 clocks and violating the requirements given in the RU IP databook figures, I decided to change the design and eliminate what I believe is a timing violation in the Intel provided Avalon wrapper around the RU IP.
I re-generated the RU IP core to eliminate the Avalon wrapper, then updated my state machine to control the reset_timer and other signals directly instead of through Avalon writes.
Testing on the new design structure is not complete, but is looking very promising.
Changing my design to directly control the RU IP has fixed the issue. If Intel is interested in pursuing the potential timing issues in the AVMM wrapper I an provide more detail on the original design, otherwise, feel free to close this ticket.
Thanks!
